66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> rebar problem
42 Posts No Rating |
hi, so i am working on structure and something is going on with vertical (perpendicular on floor plan) rebar that are not being displayed on the floor plan. it doesnt say it cant add it, i just cant see it when adding and once its added
on the screen shot i have the 3d view to show they are near and not maybe on a different place,
on the section that is going exactle across the column i am able to add and view at the same time any type of rebar without problems
and there is also the floor plan where i can only see the parallel but not the perpendicular one
hope i was able to explain this correctly and really really need help.
thanks in advance
Is your detail level set to FINE? Do you get any messages at all saying that it cannot be seen in the current view?
Edited on: Thu, Apr 26, 2012 at 7:58:22 AM
correct is setup to fine and it doesnt give any message about not being able to be seeing on current view.
Problem Linking DWG Files Showing Rebar as Polyline |
Tue, Jan 22, 2008 at 11:07:56 AM
How to apply the rebar in a ramp. |
Mon, Jul 5, 2010 at 4:53:04 AM
Rebar cover problem |
Thu, Jul 5, 2018 at 2:41:10 PM
Distribute option problem - Sofistik reinforcement detailing |
Fri, Jun 22, 2018 at 5:32:31 AM
Need help to modify rebar bar size!!!!! |
Thu, Apr 6, 2017 at 3:03:05 AM
Members: | 2000453 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
