64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Wall on a curved pedestrian ramp
2 Posts No Rating |
Hello
I am trying to creat a pedestrian ramp with landings at every 9 meters. If I want to make a wall on the side of the ramp that works as a railing, do I try the swept blend for each segment, I mean for every 9 meters I make a new swept blend wall? or is there another way?
Thanks
Similar thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=27094
Look at the bottom of this page and you will see more....
2 Posts No Rating |
Thanks Typhoon but I've reviewed that thread already and that is not the problem I'm facing.. I can do that but my problem is that I have several landings throughout the ramp itself (at every 9 meter theres a landing) so what I want to know is there a way to creat a wall that follows the curve and the slope (not a continuous slope it includes several landings)? or should I have several walls using that technique mentioned in the similar thread.
Create that with a "Railing" in one piece OR use the Swept Blend but you will need to create several....
Spiral wall along ramp |
Fri, Jul 11, 2008 at 2:42:59 PM
Sloped curved ramp... |
Sat, Oct 12, 2013 at 8:42:30 PM
12
Wall attached to Ramp |
Fri, Apr 19, 2013 at 1:19:57 AM
Structural Curved Ramp with Walls |
Wed, Apr 29, 2009 at 12:13:41 AM
A ramp! |
Thu, Jan 21, 2016 at 11:37:45 AM
Members: | 2020799 | Objects: | 22965 | Forum Posts: | 152197 | Job Listings: | 3 |
