61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Mass Floors with a Minimum Height/Clearance
11 Posts No Rating |
Hi,
In Revit Massing is it possible to control the mass floor shape so that the generated mass floors have a minimum height clearance above to the top of the mass (say 2400mm). It takes a bit of tidying up (changing the floor sketch/outline) so that it's practical after creating mass floors for a sloped mass.
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw |
I don't really understand what you are trying to achieve. Can you attach an image and try to elaborate..
Hi,
See attached picture. Hopefully that clears it up a bit.
The question is whether there is a way to control the extent of the 'mass floors' so that they don't just fill the entire mass within that level range, but takes into account the resultant ceiling height/clearance?
In the attached picture, for example, the right ends of the floor plates would need to be trimmed back to the left a bit to include only the usable (acceptable ceiling height/clearance) area.
Thanks
extruded generic model and mass floors (2012) |
Fri, Sep 21, 2018 at 3:36:03 AM
Mass Floors not all showing up - some missing |
Wed, Apr 11, 2012 at 4:44:46 AM
Electrical Clearance |
Thu, Apr 3, 2014 at 10:07:24 AM
trimming mass floors revit 2011 |
Sat, Apr 23, 2011 at 5:53:00 AM
Cable Tray Clearance |
Mon, Mar 24, 2014 at 10:44:48 AM
Members: | 1999774 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
