49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Component - Model in place - Lineweight
4 Posts No Rating |
Where do I change the Color and/or lineweight of the sketch lines for modeled in place components? We use these mostly for details and the default lines are much to heavy.
Thank you.
When you are in any view, you can switch to thin lines under the view tab. This makes all lines the same thickness on the screen only. Model element lines are controlled under object styles.
4 Posts No Rating |
I know about the View > Thin Lines. I'm refering to Home > Component > Model in place. My lines in here by default are magenta. I see no settings/lines under Object Styles that are magenta. ???
You asked :"...Color and/or lineweight of the sketch line..." I answered for the lieweight.
Sketch lines are system controlled and I don't know of any way to change the color of sketch lines.
4 Posts No Rating |
O.K. So speciffically which one do I change to adjust the lineweight of the sketch lines?
Lineweight of In-Place Families |
Thu, Apr 28, 2011 at 6:43:20 PM
Model in place component |
Wed, Oct 11, 2017 at 11:46:05 AM
Profile uploading for model in-place component sweep |
Sun, Oct 21, 2012 at 6:28:14 AM
Model-In-Place Component adhering to plan's view range. |
Mon, Apr 12, 2010 at 12:18:43 PM
cant edit my model in place component [ 1 2 ] |
Tue, Apr 12, 2022 at 3:08:17 AM
22
Members: | 2048087 | Objects: | 23053 | Forum Posts: | 152305 | Job Listings: | 3 |
