66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevation Override
I want to be able to use the spot elevation in instances where the elevation might need to be "faked" a bit. Is there a way to override the actual elevation numbers like you can with dimensions to replace it with what I want it to say with either numbers or text?
Bad ....bad...BAD! ...
I hear you....
I don't believe there are any over-rides available but you can:
- Set up different spot elevations with different units (rounding )
- Create a fake spot elevation family
- Add a small 3D line in the proper place and elevate that.
Yea not good I know but sometimes its just easier. What do you mean by create a fake spot elevation? Itd be nice to be able to add text to the spot elevation instead of the numbers.
Just edit your spot elevation tag - remove the parameter that reads the elevation and add an instance text parameter, then save under a different name and load it in your ptoject.
So I fooled with this a bit yesterday and I couldnt figure it out. The spot elevation is a system family (hard to find at first) but when I found it and opened the file under the RAC 2012\Libraries\US Imperial\Spot Elevation- Target Filled to modify it all that is there is the target head and filled region.. not text or parameters. I'm assuming that I am looking in the wrong spot, could you point me to the correct location if I am?
Sorry, I forgot that was system. You will have to make a unique symbol that still uses your cross hairs.
0 Posts No Rating |
Was there ever a solution to this?
0 Posts No Rating |
18 years later... nothing yet
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:20 PM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
Spot elevation tag issue |
Mon, Jun 3, 2019 at 3:18:37 PM
Elevation Level Override |
Thu, Apr 5, 2018 at 1:22:35 PM
Members: | 1998270 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
