42 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Ceiling Plans
I created a grid ceiling. and I cannot see it on any of the ceiling plans to place lights.
any suggestions?
First, are you using a reflected ceiling plan, not a floor plan?
Do you have ceilings on in VG?
Did you assign a grid pattern to your ceiling type?
ceiling plan... yes
VG..ceiling...on
accoustical 24"x 48"... yes grid
any others? thanks for the help WW.
You have the correct material assigned to your ceiling?
You don't have any over-rides or worksets or phases?
Your view range in your RCP is set so that your ceiling is included?
Try this - create a new RCP. - Don't use any View template.
it apears to be correct.
where do I change the view range.
or how do I create a new RCP?
thanks
View tab, plan view pull down - pick Reflected ceiling plan, then pick your level.
I did that and still cant seem to see it. I am going to try and recreate the ceiling
How to load back the Reflected Ceiling Plans into the Project Browser? |
Tue, Jun 8, 2004 at 5:41:39 PM
Floor Plans need to show Ceiling on them in Revit 2011 |
Thu, Aug 26, 2010 at 12:40:35 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting |
Tue, Sep 13, 2011 at 11:12:09 AM
Room Tags on Ceiling Plans |
Fri, Mar 4, 2005 at 9:36:28 AM
do walls join differently in ceiling plans for you? |
Thu, May 5, 2011 at 11:30:02 AM
12
Members: | 2000388 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
