61 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> blending a sweep (Modeling)
I want to model an object that goes along a sweep line, but the goes from one size rectangle to a smaller one. It will be for the McDonalds Eyebrow over the building. any suggestions? one end will be 10"x6" and the other end 6"x 4". thanks
Use the "Swept Blend", not "sweep".
when I used that I can create exactly what I want. but then I have problems rotating it in the orientation I want it in. any way around that? It wont let me pick a plane to turn it correctly.
thanks
Model it where you want it. I don't understand your problem.
Make sure constrain is unchecked before you rotate.
When you say it won't let you pick a plane, do you mean it won't let you select a plane at all or the plane you want to rotate on is not an option for you to choose from under workset plane?
Edited on: Fri, Dec 16, 2011 at 2:39:37 PM
Quote by: Holtz, Lou
blending curves |
Mon, Oct 13, 2008 at 12:22:38 PM
Blending + Revolve + Sweep. |
Tue, Jan 8, 2008 at 8:48:40 PM
roof challenge ! |
Sat, Aug 21, 2010 at 10:30:08 AM
modeling sweep/blend/void? - STUMPED |
Sat, Apr 28, 2012 at 11:56:49 AM
Could not create integral wall sweep for wall instance...... |
Wed, Oct 2, 2013 at 1:21:10 PM
Members: | 2000402 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
