64 Users Online (63 Members):
Forums >> Revit Systems >> Technical Support >> Duct Fittings showing halftone
23 Posts No Rating |
Hi guys, just wondered if any of you could help with this little question? The Ductwork in my layout is showing bold but the fittings are only showing halftone?
I have checked the VG and 'Halftone' for duct fittings does not appear to be checked? I have attached a Jpeg file
Thanks
1 Posts No Rating |
This thread is a little old but I figured I might chime in.
The issue is with the underlay setting in the view... Change the underlay setting to none and the problem will be solved.
dp
0 Posts No Rating |
I love you....
I am having this problem with piping. When I change the underlay to none all my piping disappears! Can someone tell me the correct view settings for pipe/duct work layouts. New to MEP layouts in Revit and trying to learn in our down time.
0 Posts No Rating |
good post
Ductwork showing halftone? |
Tue, Jan 3, 2012 at 3:16:55 PM
Eccentric Duct Fittings? |
Thu, Dec 15, 2011 at 10:58:31 AM
Duct won't tap to oval duct. |
Tue, Aug 22, 2017 at 12:38:49 AM
Default Duct Fittings |
Tue, Jul 20, 2010 at 2:40:22 PM
exporting revit to cad issue- duct and pipe fittings converted as blocks |
Wed, Jun 17, 2015 at 1:58:55 PM
Members: | 1999754 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
