44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Ductwork showing halftone?
23 Posts No Rating |
Hi guys,
just wondered if any of you could help with this little question?
The Ductwork in my layout is showing bold but the fittings are only showing halftone?
I have checked the VG and 'Halftone' for duct fittings does not appear to be checked?
I have attached a Jpeg file
Thanks
Is there a filter above the system filter that may be working against it? Did you check the sub categories in the VG? How
about the object styles? I am going to assume the views discipline is set correctly. Is it only on your machine or is it on
others also?
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
Hi I ended up duplicating the view to combat this issue, it seemed to resolve the halftone problem ;-)
Thanks
sounds good, i have had the same thing happen before it is frustrating.
Duct Fittings showing halftone |
Thu, Aug 11, 2022 at 1:49:20 AM
Ductwork in some views, when set to existing is not printing as halftone |
Fri, Jun 7, 2019 at 4:46:47 PM
Revit MEP > Link 3D CAD not showing ductwork |
Wed, Jan 19, 2011 at 4:54:39 PM
Filters, Fill/Surface Patterns and Halftone or Line Weight? |
Fri, Feb 18, 2011 at 3:11:12 PM
REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser |
Wed, Mar 20, 2013 at 3:31:59 PM
Members: | 2048108 | Objects: | 23053 | Forum Posts: | 152305 | Job Listings: | 3 |
