44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> How do I make curb
In my site I have a curb. I just created it as a floor. Is there an easier way? How can I go about making the curb with an rounded top corner?
We find these easier to do as walls. If you insist on modeling the round corner, you can use a wall sweep (reveal) if a wall, an in-place void sweep or if a floor, a floor edge sweep.
I have posted this many times, if you want an accurate result. This will work pretty well although fairly complicated.
typically I'll do it as a wall like Hub mentioned. However if it is in the forground of a rendering similar to yours, I'll accurately model the curb as an in-place sweep. I have a profile family setup for our local standard and then apply that to my sweep path. Check your local standards but this is how curbs typically looks here in Ontario...
http://www.raqsb.mto.gov.on.ca/techpubs/ops.nsf/d37f5a16d8174ffa85256d130066857f/b0a8704ef49f5626852572c600647bc4/$FILE/OPSD600.040%20Rev%231%20Nov2006.pdf
thanks, I made it as a model in place. sweep, site family
thanks for all the suggestions. any more suggestions
How to do a road curb that follow a sloped roadway? |
Mon, Aug 12, 2013 at 1:34:06 AM
street/curb solution |
Sun, Jul 6, 2008 at 9:44:06 PM
brick/block wall on curb |
Fri, Sep 26, 2003 at 2:57:15 PM
how to add elevation to curb sweeps? |
Fri, Feb 4, 2011 at 3:54:40 PM
Lifting up building for curb |
Sun, Dec 30, 2007 at 1:21:28 PM
Members: | 2000493 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
