50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how do I show great detail in mortar on bricks
Mon, Dec 12, 2011 at 11:42:13 AM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
My renderings appear too flat. I would like more detail in my brick scaling and details they show
Mon, Dec 12, 2011 at 12:15:05 PM | how do I show great detail in mortar on bricks
3.5 Stars: 391 Votes
Is this a rendered or shaded view?  Brick should work fine at this view scale so you have done something wrong.
Mon, Dec 12, 2011 at 12:44:15 PM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
rendered view and I can not seem to be able to even see the brick pattern at all. Suggestions?
(make scene bigger first)?
Mon, Dec 12, 2011 at 12:54:20 PM | how do I show great detail in mortar on bricks
4 Stars: 201 Votes
Did you change the "Scale" of that brick material?
Mon, Dec 12, 2011 at 1:07:57 PM | how do I show great detail in mortar on bricks
Apply the right material.  Zoom in and render - I don't believe that wall has a brick material applied to it.
Mon, Dec 12, 2011 at 1:35:41 PM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
WWHub, thanks for your help. here is how I have that brick wall set. are these settings right? thanks and typhoon I am re scaling it now. thanks
Edited on: Mon, Dec 12, 2011 at 1:37:02 PM
Edited on: Mon, Dec 12, 2011 at 1:37:57 PM
Mon, Dec 12, 2011 at 1:53:06 PM | how do I show great detail in mortar on bricks
If you used the standard bricks, you don't need to scale because they are already correct.  Typhoon was asking if you had scaled them or if you created your own brick pattern had you set it correctly.
Mon, Dec 12, 2011 at 2:12:15 PM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
I used a standard brick image and never modified it. and that rendering is what it did.  I used running- red. I just changed the scale and increased the dpi and image size. so when I print it I don't have to scale it up.
Mon, Dec 12, 2011 at 2:39:54 PM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
I still can not seem to get them mortar joints to show up. What is the best brick pattern to use, that I can change the color on?
Tue, Dec 13, 2011 at 10:19:51 AM | how do I show great detail in mortar on bricks
rambo6
4 Stars: 4 Votes
I increased the bump image and how much its value is. would that be how to add detail?
Tue, Dec 13, 2011 at 10:34:12 AM | how do I show great detail in mortar on bricks
#11
NO!  Bump size will not help you.
The color of the mortar and the brick is managed through the jpg image.  Either find an appropriate material image or edit the colors in an image program.
Tue, Dec 13, 2011 at 11:28:59 AM | how do I show great detail in mortar on bricks
#12
rambo6
4 Stars: 4 Votes
what is the bump image for. whne i changed its value from 0 to 1000, now I can actually see the bricks.  So dont use that?
Tue, Dec 13, 2011 at 11:44:25 AM | how do I show great detail in mortar on bricks
#13
From your HELP....
Bump:>  For texture properties, such as Finish Bumps and Bump Pattern, specify a value for Amount.
This value specifies the amplitude of surface irregularities. Enter 0 to make the surface flat. Enter higher values to increase the depth of the surface irregularities.
Basically, this adds depth to your surface.
As I said, Find an appropriate material image.  Did you look at all of the standard brick materials already avialable to you in the program?
Thu, Dec 15, 2011 at 2:25:32 PM | how do I show great detail in mortar on bricks
#14
rambo6
4 Stars: 4 Votes
I think part of my problem was that I changed the color of running red. but I left the image on too much.
running bricks
Wed, Oct 8, 2008 at 2:51:43 PM
Edited window family falls apart when placed in a project.
Thu, Dec 1, 2011 at 4:03:22 PM
Bricks are twisted... materials going up instead of sideways
Thu, Jul 21, 2011 at 2:30:06 PM
stretcher bond with mortar joint - custom
Mon, May 6, 2013 at 3:10:08 AM
conc block pattern is not showing correctly
Wed, Mar 14, 2007 at 3:38:26 PM
Page generation time: 0.8806
