38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Problem w/ creating a glass panel dome
Mon, Oct 31, 2011 at 2:06:37 PM | Problem w/ creating a glass panel dome
jeedjard
I have a problem with creating a glass panel dome, actually that dome is the existing building "The Joe and Rika Mansueto Library", the problem is when I used a revolve method to created a mass then I created a curtain system on that mass and also created mullion on that system. The result was nice except thatthe horizontal  mullion place on the wrong way. I guess that the mullion follows the method of revolving when I have created a mass at first.
So, Is there anyone know how to fix this problem ? or Any suggestion for creating this building
PS: I have attached 2 pictures, one is the questionable model that I have made and another is the reference "The Joe and Rika Mansueto Library" building.
Mon, Oct 31, 2011 at 2:43:57 PM | Problem w/ creating a glass panel dome
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
i would use the conceptual massing tool and create this form. you're not going to be able to recreate that pattern with a curtain system. well... unless maybe if you match that form better so it flares out near the bottom instead of being a revolved ellipse
Edited on: Mon, Oct 31, 2011 at 2:49:15 PM
Mon, Oct 31, 2011 at 6:34:27 PM | Problem w/ creating a glass panel dome
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Also check this post , i think you can do that better with intersect tool
Norman Foster's Glass Dome problem
Mon, Jul 16, 2012 at 9:19:54 AM
Another Question about Creating Glass Dome !!!
Sun, Jan 13, 2013 at 7:59:11 PM
a dome of glass ??? [ 1 2 ]
Wed, Nov 26, 2008 at 1:48:50 PM
17
Problem selecting glass using tab key
Thu, Mar 21, 2019 at 1:17:37 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Page generation time: 8.5683
