57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Activate Dimension
32 Posts No Rating |
Why does the dimension act differently in these two cases
- Create a new wall and dimension to grid, slect the wall and the dimension becomes editable and the wall will move to the new dimension valus.
- Dimension to an existing wall in the project, select the wall, sometimes the dimension imeadiatly becomes editable, sometimes you have to "activate Dimensions" to make the wall move via the new dinmension value.
What is driving the case thhat requires the "activate dimension" step?
11 Posts No Rating |
I'm having this same problem, has anyone found an answer
I wish I could explain the "rules" but I can't.
I will say this. Users often think they are dimensioning to an element when they are really dimensioning to something else in the same place. Then that dimension does not activate because it isn't what they thought it was. Be careful when dimensioning and watch in the lower left corner of you screen what you are reallly dimensioning to/from.
I'm having this problem too, but only with doors in one project.
In the other projects when I select a door the dimensions appear but in this one project, just for doors, I have to click on the 'activate dimension' every time.
What's up wit dat?
It's got to be happy hour somewhere |
Activate View |
Thu, Aug 6, 2009 at 7:24:39 AM
Where are my temporary dimensions? |
Tue, Jan 12, 2010 at 12:29:17 AM
What happened to "activate dimensions"? |
Wed, Jul 1, 2009 at 2:34:44 PM
'Activate View' on sheets |
Tue, May 7, 2013 at 11:26:56 AM
Dimension strings not adding up to the total length dimension string (2017) |
Fri, Mar 23, 2018 at 1:33:58 AM
Members: | 1999807 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
