72 Users Online (70 Members):
Forums >> Revit Structure >> Technical Support >> Unknown Run-Time Error (Revit to Robot)
2 Posts No Rating |
Hi, good day, I am actually new in revit, I am using Revit 2011, Lately, i've found out about this Robot structural analysis 2012 and i get a copy of it.
i also downloaded the revit extension,. I tried to export my revit file to robot but i get an error saying
"Unknown Run-time Error"
can you help me with this? thanks
2 Posts No Rating |
Hi, Good Day, can anyone help me with this problem? it would be a great help..
1 Posts No Rating |
I am also getting this error. It happens when i try to update my revit structure objects with ones i modified in Robot.
It should be noted that the error only seems to happen when i try to import the object along with reinforcements. If i chose to update the object but without importing the reinforcments, i get no error.
If anyone solved this problem or knows a solution please reply to this.
Thanks alot
0 Posts No Rating |
I'm having the same issue as Phikwe ten years later it seems): getting the run-time error when trying to go back to Revit from Robot. The only difference is that I get the error wether I import along witih reinforcements or not.
As for getting the error during the inital export from Revit to Robot, this guide might help: https://knowledge.autodesk.com/support/robot-structural-analysis-professional/troubleshooting/caas/sfdcarticles/sfdcarticles/REVIT-TO-ROBOT-LINK-run-time-error-exporting-model-from-Revit-to-Robot-on-W10.html
I found that it did not help for my problem though.
0 Posts No Rating |
UPDATE: I solved my above problem by populating all my load combinations - I had created a load combination and forgot to add cases to it. Once I populated that comnbination, I no longer had an issue exporting back into Revit from Robot.
Error message when importing Robot Millennium buildingmodel |
Mon, Mar 5, 2007 at 5:13:15 AM
revit structure to robot millennium |
Fri, Dec 26, 2008 at 4:08:18 AM
Render Calculation Error? [ 1 2 ] |
Fri, Jun 7, 2013 at 7:53:38 AM
19
" an unknown error occurred while accessing ....central.rvt" |
Wed, Oct 11, 2017 at 12:53:21 AM
Error: Revit was unable to render the view due to an unknown error. |
Mon, Apr 28, 2014 at 3:32:17 AM
Members: | 1999760 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
