48 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Printing PDF's
36 Posts No Rating |
We use PDF's for all of our printing, Does anyone know how to print multiple sheet views into one pdf, instead of seperate pdf's?
16 Posts No Rating |
Hello:
Hello:
I use Acrobat Professional to combine single page PDFs into one large multi page PDF file from one or more sources.
-Loren
28 Posts No Rating |
Well, I don't know if it was a fluke or what, but the other day I discovered how to do this. We use the Cute PDF writer, and for some reason it was set to do multiple copies and collate when I printed and it printed all m y sheets in one PDF. You could try that.
Vanessa
Thanks for you response - Cute PDF did not work for me.
I figured out how to get around the limitations of Revit...In case anyone wants to know
You can print all sheets to one file as a DWF file - Then open the DWF and print to PDF.
It also makes the file size smaller than combining pdfs and cuts your printing time in half because you don't have to give a file name to every sheet. Works great for our project which is over 30 sheets.
1 Posts No Rating |
You can use "pdfFactory Pro"!!
I use it
14 Posts No Rating |
when you first enter the plot command, right in the middle of the dialog box is a toggle for whether you want it to print into multiple PDFs, or one single giant one.
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
pdf selections |
Sun, Oct 22, 2006 at 3:24:52 AM
Printing a set as PDF's |
Sun, Sep 24, 2006 at 8:56:03 PM
Printing Shadows in .pdf file - Revit 7.0 |
Wed, Dec 22, 2004 at 9:16:23 AM
Members: | 2000497 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
