43 Users Online (42 Members):
Forums >> Revit Structure >> Technical Support >> Section in Revit
7 Posts No Rating |
I linked Arch revit file into Revit structure. i have attched the section image. I want to hide the arch slab portion in section. I will turn off Floor in VG it will turn off arch slab and structural slab also. so how can i control view of any reference file so that in section it will display structural slab only which i have drawn in plan.
Thank you
You will want to search the help file for controlling the visibility of linked elements and how to use linked views.
VV -> Revit Links Tab -> Custom Settings -> Model Categories -> Custom from pulldown -> Floors off.
Also, if you intend to repeat this set-up say...15 times in a project, create a view template.
Make sense?
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Attach Building Section Heads to Section Box |
Mon, Sep 21, 2015 at 4:53:57 PM
Section tag missing on plan but section still exists |
Tue, Nov 22, 2016 at 2:58:15 PM
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Section cuts WAAY too deep! |
Tue, Jun 7, 2011 at 5:34:55 AM
Members: | 2000493 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
