59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> How do you chamfer two different wall types?
25 Posts No Rating |
Trying to chamfer a regular curtain wall type with a basic gyp board wall type. Is this possible without an elaborate work around? Any help is appreicated. thanks
"sorry, this is for revit 2011
What do you mean by chamfer? <<< BAD term here I think.
Do you mean join a normal wall to a CW at a 90?... at a 45? ... or at a 90 but miter the join?
Please clarify your question.
I am trying to mitre two different wall types at a 135 degree angle. One wall is a curtian wall at 90 degrees and should stay at that angle. The other is a gwb wall and currently the curtain wall mullion is interesecting the end of the gwb wall.
I would like to mitre the end of the gwb wall at 45 degrees to the curtain wall mullion.
You are still not clear because I think you are talking angles in plan and maybe elevation. If you mean the CW ends with a normal 90 in plan and intersects a wall at an angle in plan? Then turn off the wall joins for the CW. And add a vertical in-place vertical void to cut the end of the drywall wall with a 45.
You have it right. The scenario is competely in plan. I will proceed with your suggesting that the two walls wont actually be joined.
Thank you for the tip!
Foundation wall chamfer |
Thu, Sep 29, 2011 at 10:58:22 AM
chamfer |
Mon, Apr 7, 2008 at 4:59:25 PM
chamfer edges |
Mon, Jan 18, 2010 at 11:15:46 AM
Chamfer top of foundation wall |
Wed, Dec 10, 2008 at 12:14:19 PM
Embedded Angles won't chamfer |
Tue, Apr 17, 2012 at 8:23:58 AM
Members: | 2000371 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
