77 Users Online (77 Members):
Forums >> Revit Structure >> Technical Support >> ROTATE ELEMENT
12 Posts No Rating |
I know I must be missing something, but I cannot rotate a channel 90 degrees to use as a girt. I also found out I cannot rotate a beam that way either. Surely there must be a way to rotate the member, can anyone tell me what I'm doing wrong?
Thanks....Terry
Yes you can, if you have a beam placed on the model, then select the beam and choose edit workplane under the option bar and pick any vertical plane (or reference plane)
that's it
In plan view when selected the properties box should allow you to rotate the object under cross section rotation, may work in elevation as well but does not seem to be available in section.
mbsteve,
Cool trick, it works on section and even 3D view as well
I have used beam system as girt before, just have to edit the work plane (to the vertical plane) of the beam system and you can lay the entire wall with girt.
Mbsteve Thank You so much, I knew there had to be something simple I was missing and it was driving me crazy. This has now allowed me the correct orientation.
Thanks.......Terry
Cannot Rotate Element Into This Position?! [ 1 2 ] |
Mon, Aug 17, 2020 at 3:35:03 PM
18
help! How can I... |
Tue, Apr 14, 2009 at 1:10:36 AM
rotate the entire model |
Mon, Feb 21, 2011 at 9:18:55 AM
14
PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014) |
Wed, Jul 9, 2014 at 2:43:28 PM
3d rotate |
Fri, Sep 28, 2018 at 7:16:26 AM
Members: | 1999882 | Objects: | 22885 | Forum Posts: | 152180 | Job Listings: | 3 |
