77 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> error loading linked cad file
Tue, Apr 19, 2011 at 10:53:18 AM | error loading linked cad file
quinn
error pops up when itry to reload al inked cad file.  Linked file "file" could not be located.  it will be displayed as it was when this project was last saved.  Any solution to this?  I cant reload from or reload it and the file has always been in the same folder. ....
Tue, Apr 26, 2011 at 7:34:32 PM | error loading linked cad file
mhans
3 Stars: 10 Votes
It happened to me a couple of times. You can reload it but you can remove it and re-insert a fresh copy. If you need to move it after inserting, make a basepoint (a known corner) from the original file before you remove the file so you know where you would place the new insert. And hope it won't happen again.
Motto: "No Post left behind"
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:15 AM
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:35 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:57 AM
unable to view linked CAD file with pipe
Thu, Apr 18, 2013 at 1:36:28 PM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:51 AM
Page generation time: 0.8076
