65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> roof with ellispe
1 Posts No Rating |
Hi guys,
My English is not best, I hope you understand what I mean : ).
i have a problem by creating a roof (mass). The basic layer is a ellipse. The other two elements are Start-End-Radius-Arcs (to get roof height). (look at the picture one)
My problem is, that Revit 2010 don´t create a form with these 3 elements. And if I use only the two start-end-radius-arcs, there will be no elliptic layer at the basis. There will be some kind of overhang (picture 2).
Please, if somebody has an idea, help me.
Thanks…
Greets from germany
I don't understand why people isist on using true ellipse's. Tell me how they will lay it out in the field....how do you dimension it?
When we hand drafted and needed an ellipse (before templates '60's), we always used an approximation as described in the first link below.
http://etc.usf.edu/clipart/76200/76201/76201_ellps_4cntr.htm
This link shows how close an appromation is to a real ellipse - note that very long, thin ellipses do not work as well.
http://www.uwgb.edu/dutchs/MATHALGO/Ellipses.HTM
What describes these "approximate" ellipses are simple arcs and those you can use to do your geometry. AND NOBODY WILL KNOW IT IS NOT A TRUE ELLIPSE!
If you want an ellipse here you have the file so you can see how was made.
Roof design problems |
Fri, Jul 9, 2010 at 7:30:00 AM
12
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
problemed roof |
Fri, Mar 23, 2007 at 5:12:30 PM
Roof problems! |
Sun, Feb 1, 2004 at 7:26:42 PM
Joining a conical roof to a gable roof or other rectangular roof |
Tue, May 28, 2013 at 9:29:25 AM
Members: | 2018257 | Objects: | 22957 | Forum Posts: | 152185 | Job Listings: | 3 |
