56 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> problem with decals
42 Posts No Rating |
hi i am using revit 2011 and when i place a decal i can see the square where it will be but when i render the wall it just appears like a blurry spot where the decal should be. it doesnt look nothing like what the decal should be i have uninstalled and reinstall and still the same problem. i have tried on Revit Arch and Revit Mep and happens the same
i added 2 screenshots, before and after the render
take a screenshot of your decal type settings, that's likely where something is haywire. my guess is that you have the transparency of the decal set pretty high.
Edited on: Fri, Mar 18, 2011 at 4:14:13 PM
Hmm.. I don't know. Here's a decal I made, of your screenshot. Only difference in the settings is that I set the reflectivity to Matte... set the bump to zero, and no pattern (shouldn't matter since default is no pattern anyway) and I set the self-illumination to "dim glow" also, play with the post-render controls of brightness, midtones, and darks. Medium quality really improves the detail of the decal too, over draft or low.
still no luck, i played around with the decal settings and no luck
i just reinstalled and now after rendering it doesnt show anything at all just the plain wall
problem rendering decals |
Tue, Aug 3, 2010 at 8:18:16 AM
problem with rendering decals |
Mon, May 14, 2007 at 5:44:57 PM
Decals to 3ds max |
Fri, Aug 28, 2009 at 9:19:06 AM
Decals not showing.. |
Fri, Feb 16, 2018 at 9:39:04 AM
12
Decals not Rendering in 2010/12 |
Wed, Jul 20, 2011 at 1:34:53 PM
Members: | 2000441 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
