51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Arched storefront doors...?
Mon, Mar 14, 2011 at 10:36:31 AM | Arched storefront doors...?
arusso5
Hello, I'm working in Revit Arch 2011 (which I'm loving by the way).  I'm working on some existing storefront for a project I'm working on.  All of the storefront is arched.  No problems there, I'm able to make the storefront look like I want it.  The problem comes when I have arched doors in the storefront.  I have loaded the single glass and double glass doors and tried to insert them and Revit will not arch the tops of the doors.
Am I missing something?  I can't find anything on this topic.  Do I have to create the doors with the correct arch top first?  Has anyone done this already?
Thanks in advance.
Mon, Mar 14, 2011 at 2:32:17 PM | Arched storefront doors...?
pchan
pchan Avatar
5 Stars: 5 Votes
in the typical storefront/curtain wall set up, all the vertical and horizontal mullion are meant to linear, therefore, no curve/slope of such can stay within the system
I know that you can edit profile to get the edge of the storefront to be arch shape but you can't (typically) curve an arch door way within the curtain wall. (ie the curtain panel does not allowto be curved)
One of the workaround would be to model the entire storefront and arch door as wall based family then insert it to the wall.
OR you can model a custom curtain panel that has a arch door with the straight transom within the same panel.
Mon, Mar 14, 2011 at 2:46:36 PM | Arched storefront doors...?
pchan
pchan Avatar
5 Stars: 5 Votes
It could look kind of like this
See attached
Mon, Mar 14, 2011 at 3:00:38 PM | Arched storefront doors...?
4 Stars: 202 Votes
Just edit the profile (not the panel but the Curtain system or storefront) like you want and the mullions will be curved.
Tue, Mar 15, 2011 at 2:47:30 PM | Arched storefront doors...?
arusso5
pchan and Typhoon,
Thanks for the responses.  Typhoon, your left image is pretty much what I was doing.  Can you place the surtain wall doors in this though?  That's the issue I was having.  I can create the arched storefront, but when I try to switch out the glazing panel for the storefront double doors, Revit tells me it can't be done.
Can you place the doors in your solution?
Tue, Mar 15, 2011 at 2:51:15 PM | Arched storefront doors...?
4 Stars: 202 Votes
That's not a "Curtain Wall door", that is a ANOTHER curtain wall, then I edit the profile, create that shape and added a curtain grid in the middle, just like that....
Tue, Mar 15, 2011 at 3:12:28 PM | Arched storefront doors...?
arusso5
If it isn't a door, then its just another work around.  I have specific doors to place in the storefront.  Thanks anyway.  Looks like I'll have to find yet another way to make Revit do something.
Tue, Mar 15, 2011 at 3:29:56 PM | Arched storefront doors...?
pchan
pchan Avatar
5 Stars: 5 Votes
Arusso5,
you can try and see the attached file and see if this solution will work for you.
Wed, Mar 16, 2011 at 12:31:28 PM | Arched storefront doors...?
arusso5
pchan-
 Thanks for the doors.  They didn't do exactly what I was looking for, but it gave me an idea to do what I needed.  I modified the double storefront doors to have the radius top that I needed, then I replaced the single arched glazing panel with a generic wall which took its shape.  Then I inserted my arched doors into the wall in the storefront.  The doors show correct in all views and schedule as doors.
Thanks again for the help and inspiration.
Wed, Mar 16, 2011 at 12:38:56 PM | Arched storefront doors...?
pchan
pchan Avatar
5 Stars: 5 Votes
Door inserted in basic wall that use it as a Curtain wall panel is also another solution to it.
Sounds like you get the idea
Storefront Doors
Sat, Jun 11, 2011 at 8:49:02 AM
Storefront Wall needs Storefront Doors
Mon, Dec 3, 2007 at 8:58:53 AM
Creating Arched Storefront in curved wall
Thu, Jan 24, 2013 at 10:15:12 AM
Creating a arched storefront window in an exisitng generic 8" wall
Thu, Mar 18, 2010 at 10:50:10 AM
Storefront Doors in Door Schedule
Wed, Sep 9, 2009 at 4:32:18 PM
Page generation time: 0.4984
