60 Users Online (59 Members):
Forums >> General Discussion >> Revit ROI >> Can select Walls
1 Posts No Rating |
I am working on a model started by someone else and there are walls I cannot select. I have tried in plan views section custs through the walls, elevations and nothing seems to work.
Different Phases? Worksets? Design Options?
"I am working on a model started by someone else and there are walls I cannot select. I have tried in plan views section custs through the walls, elevations and nothing seems to work."
What version are you using?
Try to check your status bar.The "Select Pinned Element" mark as "x" located at the lower-right side of your screen.Remove the sign "x" by clicking. then try to select the wall.
And if your wall is a Revit link use TAB to be able to select.
Can't select Wall and Grid - Not Design Option fault |
Thu, Jun 20, 2013 at 10:30:13 AM
Received revit model from client and can't select certain walls |
Mon, Apr 4, 2016 at 3:49:04 AM
Select all by type |
Thu, Dec 23, 2010 at 9:12:52 AM
Picking multiple faces when creating walls |
Fri, May 6, 2011 at 2:12:40 PM
Stacked Walls - Can't select wall layers |
Mon, Jun 24, 2013 at 3:14:41 PM
Members: | 1999341 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
