77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimension problem when exporting Revit to DWG
Fri, Jan 14, 2011 at 10:26:12 AM | Dimension problem when exporting Revit to DWG
davidarcdox
Hi,
We are having a problem exporting files to DWG, everything is okay except the Dimensions. For a sheet exported with two Views, the dimensions appear to have different fonts. One Arial which is fine, but the other just displays a simplex txt. The txt text is cluttered and unreadable. Is this a glitch or are we doing something wrong??
Thanks
Fri, Jan 14, 2011 at 10:34:37 AM | Dimension problem when exporting Revit to DWG
rkitect
rkitect Avatar
4 Stars: 29 Votes
Are all the fonts in your revit file the same across all dimensions? Are you using multiple dimension types in Revit? Annotations is something I've never seen translate correctly to DWG from Revit, but some claim they do it on a regular basis with 0 problems.
Fri, Jan 14, 2011 at 10:44:15 AM | Dimension problem when exporting Revit to DWG
davidarcdox
We use Arial as an office standard across the board. We use multiple dimension styles too but the all print fine in DWF PDF and from Revit. Even when we export using Xrefs they dont display correctly, but when you open the xref file it all looks fine. Weird!!
Fri, Jan 14, 2011 at 11:04:34 AM | Dimension problem when exporting Revit to DWG
davidarcdox
Problem solved. Well kind of a work around. When we exported the files we saved them as AutoCad 2000 files. this fixed the problem to an extent, but when you resave the DWG file as 2004,2007,2010 the problem reoccurs.
Tue, Apr 12, 2011 at 11:15:44 AM | Dimension problem when exporting Revit to DWG
Bimman
Bimman Avatar
1 Stars: 2 Votes
I WAS HAVING THE SAME PROB AND DID THE VERSION 2000 SAVE AS AND IT WORKED FOR AS WELL NOT, SURE WHY IT DOESNT WORK FOR ANYTYHING AFTER 2000.
PWD
Problem with Exporting to dwg with multiple layers for use in 3D Studio
Mon, Dec 13, 2004 at 5:21:22 AM
DWG Conversion Dimension Style
Mon, May 10, 2010 at 8:28:14 AM
Exporting views for DWG
Thu, Oct 24, 2019 at 5:52:24 PM
Problem exporting to DWG
Wed, Mar 12, 2008 at 12:02:42 PM
Exporting a Revit project (contains linked files) to dwg - coming in as Blocks
Mon, Mar 21, 2011 at 3:03:59 PM
Page generation time: 3.0918
