62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> X, Y, Z SOLID EXTRUSION
Wed, Jan 5, 2011 at 8:51:14 AM | X, Y, Z SOLID EXTRUSION
lavendi321
4 Stars: 16 Votes
My company works alot with water slides, in public parks. I did a topo surface of a park, and need to inlay a water slide. the one in this picture was provided to me by a water slide designers from AutoCad. I am pretty sure I can generate a slide using a 3d polyline in Autocad (I think).
My question is, is there a way in Revit 2009 (or Revit 2011) to generate a x,y,z, solid extruction, or sweep, so I can assign a slide profile along a path that curves, both in plan and section, like a water slide/
 Thanks
Wed, Jan 5, 2011 at 8:53:08 AM | X, Y, Z SOLID EXTRUSION
Thread Post Kudo! Thread Post Kudo! Thread Post Kudo! #2
lavendi321
4 Stars: 16 Votes
Here is the image if the water slide I was provided. I need to create a similar slide.
Thanks
Wed, Jan 5, 2011 at 9:48:09 AM | X, Y, Z SOLID EXTRUSION
No need to recreate this in Revit if you can get the 3D CAD file.  Just import the slide into a Revit Family and set the materials to the CAD layers.  The CAD file should not include the site or the pool - just the slide supports... etc.
Wed, Jan 5, 2011 at 11:42:40 AM | X, Y, Z SOLID EXTRUSION
lavendi321
4 Stars: 16 Votes
Thanks, but thats not the issue. I need to creat NEW slides. I need to do an existing condition model, showing the existing slides, and surrounding slides at this water park.
Anyone know if and how to generate an x, y, z solid sweep of some sort so I can generate water slides.
Thanks
Wed, Jan 5, 2011 at 12:02:16 PM | X, Y, Z SOLID EXTRUSION
Did you search the forums.... nope - start with this one: http://www.revitcity.com/forums.php?action=viewthread&thread_id=6931
I searched "3D sweep"
BTW .... This is still easier to do in CAD and import....
Edited on: Wed, Jan 5, 2011 at 12:03:10 PM
Solid Extrusion Question
Wed, Aug 2, 2006 at 9:32:08 AM
SOLID EXTRUSION COLOR
Sat, Mar 7, 2009 at 11:04:09 AM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
How do I assign materials to a solin extrusion?
Tue, Oct 17, 2006 at 6:42:52 PM
Editing Solid Extrusions
Sun, Jul 30, 2006 at 9:00:52 PM
Page generation time: 0.3563
