73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Creating a dimension where one end doesn't dimension to a specific point
8 Posts No Rating |
I have an issue with the dimensioning in a drafting view. I am creating a roof detail and am giving it a dimension to tie it to the finished floor line. I am not showing the floor line, so I want to create a dimension that uses two arrowheads to represent that it is dimensioned to the finished floor line that is not shown...any ideas on how to do this? I am using Revit Architecture 2011.
Add a line and dimension to that.
8 Posts No Rating |
Good idea...thanks The thing is, is there a way to do this without tieing to a second line and also create a second arrowhead on the one side to show that the dimension keeps going beyond the end of the dimension line
Yes... It is called linework and text - not a dimension. If you want to fake something then fake it! A dimension is real.
As an alternative, you can use a line based detail component...just be careful that you don't start using it inlieu of the dimension command.
Dimension String Doesn't Equal Overall Dimension |
Wed, May 27, 2009 at 2:33:49 PM
Dimension String |
Wed, Nov 22, 2006 at 3:05:15 PM
How to make an aligned dimension? |
Wed, Dec 11, 2013 at 5:19:54 AM
When mirror why dimension won't stay the same |
Fri, Mar 13, 2009 at 4:42:26 PM
CREATING DIMENSION STYLE w-embedded text? |
Thu, Jul 24, 2008 at 1:33:50 PM
Members: | 1999786 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
