80 Users Online (79 Members):
Forums >> Revit Systems >> Technical Support >> Electrical Panel Schedule
2 Posts No Rating |
PLEASE HELP !!! I have a layout of all my outlets in my bldg including my panel board, but when I select Panel A (my main panel board) and then go to the ribbon and select "create panel schedule" then "use default Template" My schedule comes up completely blank....what am I doing wrong or have I missed a step??? Please help Brian
Add each fixture to the panel selected.
2 Posts No Rating |
I did add each fixture to the panel...and nothing shows up when I go to Panel Schedule.....when I am on the Panel Schedule sheet you can click on it and see the cell and column outlines but the sheet is blank.
these helped me, http://tinyurl.com/27tnqu2
1 Posts No Rating |
Hi! Brian1969,
did you find any anwer for your problem on panel schedule??? i have the same problem, and even doing exactly as tutorials say, the panel schedule makes blank! did you solve your problem? please!!!!!!
For anyone else who has this problem, this thread helped me.
https://forums.autodesk.com/t5/revit-mep-forum/panel-schedule-template-is-blank/td-p/6551434
2 Posts No Rating |
I have found that you need ot create a complete distribution system for all the electrical to connect.
Go to the Mange tab > MEP Settings > Electrical Settings, then look under Voltage definitions and Distribution Systems, make sure all these are fille dout, this will aloow all your recetplaces and switches to connect to your panel board. Then your panel will populate when oyu double click on you panel board and select the DEFAULT TEMPLATE
Custom MEP Electrical Panel Schedule |
Fri, Jul 13, 2012 at 1:45:21 PM
Applying Electrical panel schedule templates in 2011 |
Thu, Sep 9, 2010 at 11:17:50 AM
adding existnig loads to electrical panel |
Tue, Feb 23, 2010 at 9:32:02 AM
Electrical Panel Schedules |
Mon, Dec 14, 2009 at 2:36:28 PM
Panel Schedule help |
Fri, Jul 19, 2013 at 12:56:51 PM
Members: | 1999760 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
