61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> OUTSIDE STAIRS
Tue, Dec 7, 2010 at 7:39:43 PM | OUTSIDE STAIRS
terrywu218
terrywu218 Avatar
Hello guys,
I am setting up a entry stair. The stairs need solid space as the pic shown. But the only way I knew is "component-model in place" and there is a clear line between stair and that component. "Join" commend is unavailable to the effect here. Does anyone know better way than adding component?
 Thank you!!
Tue, Dec 7, 2010 at 11:03:18 PM | OUTSIDE STAIRS
paulh
Thats the best way I know how. The line can be removed from a view with the linework tool.
Wed, Dec 8, 2010 at 6:00:55 AM | OUTSIDE STAIRS
4 Stars: 202 Votes
You can create a "Wall" (instead of in-place)  then edit the wall with that shape, to "Clear" that line use the "Linework" tool "Invisible line"
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 0.2319
