45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Shared parameters with profiles
Tue, Nov 23, 2010 at 1:27:32 PM | Shared parameters with profiles
JeroentjeM
Hello,
 it's not possible to make shared parameters when creating a profile.
My thought was: if I make a profile with adjustable height and thickness, for like some wooden casework. And use shared parameters, I then can create this casework in the project with in example a fascia, and then make a fascia schedule. From here I can see the length, but I also would like to see the parametric height and thickness value. So if I make a calculation, I can exactly see what kind of casework is used....?
 But since the shared parameters aren't an option with profiles...how does one do this magic?
 Thanks!
Jeroen
Shared Parameters
Thu, Feb 9, 2006 at 1:41:59 PM
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:12 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:43 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:09 AM
Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:31:27 AM
Page generation time: 0.3485
