70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Property lines question
Fri, Oct 29, 2010 at 5:56:15 PM | Property lines question
Nicincad
I've never really understood the property line table, and just can't get it to behave the way I wan't. I've so far only had straight lines so it hasn't really been an issue but this time I'm looking at a lot with arcs. I've enclosed pictures and while I'm at I thought I would ask a couple of related questions:
1) If you look at the table and my drawing the curves doesn't look entirely correct? Also, the manual says I should enter L if the curve is to the left to the preceding line? I used common sense and adapted to curvature. Do you agree with my table?
2) I get a fill line of about 6' when guess the angle of the first curve to 44 degrees. Can you see from the plat which angle it should be? I shouldn't have to guess it, right?
3) How can I create an annotion line that gives a 40' setback all around? Offset tool or something more dedicated?
Fri, Oct 29, 2010 at 10:58:22 PM | Property lines question
Nicincad
Another hint that something is wrong is that looking at the area in properties I get 29,831 sqf whereas I know the property should be around 29,700.
property lines hidden by topography
Tue, Mar 6, 2007 at 11:47:47 AM
Property Lines + True North Rotation
Thu, Apr 26, 2012 at 2:34:45 PM
Property Lines on Toposurface
Mon, Jul 9, 2007 at 10:22:49 AM
Property Lines
Sat, Oct 6, 2012 at 11:03:50 PM
Progataing property lines to floors
Fri, Mar 18, 2011 at 4:25:43 PM
Page generation time: 0.9054
