129 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Combine Areas in Area Schedule
Thu, Aug 19, 2010 at 12:46:56 AM | Combine Areas in Area Schedule
camncam
Hi I have a house with front and rear decks and I want to group them together in my area schedule as simply "External" space rather than having 2 lines saying "Rear External" and "Front External". Is this possible?
Thu, Aug 19, 2010 at 10:26:11 AM | Combine Areas in Area Schedule
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't think you can combine the two areas but you can form sub totals in the schedule and add the two up.
Thu, Aug 19, 2010 at 12:06:14 PM | Combine Areas in Area Schedule
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
It's not that you can't combine them on the schedule...that is easy to, just give them an identical property and sort by it.
The problem is that you will  get a blank space on your schedule for any field that is different between them like an area name or number, or the area value itself. The are value can be filled in by simply making it a calcualted value, but the name or number would have to be the same for anything to populate in that filed.
See the attached image, the schedules the same, but the bottom has the two exterior areas combined into one row.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Area Plan - merge or combine areas?
Mon, Sep 9, 2013 at 4:32:00 PM
Areas and area schedules in Revit 2013
Fri, Mar 18, 2016 at 7:27:55 AM
Schedule Rooms Within areas of a specific area plan
Mon, Nov 25, 2013 at 12:59:18 PM
AREA SCHEDULE INCLUDING WALLS
Tue, Sep 13, 2005 at 9:50:03 AM
Floor Areas and Shaft Areas
Tue, Jul 29, 2008 at 3:04:18 PM
Page generation time: 3.3484
