69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit MEP 2010 plan region HVAC problems
Thu, May 6, 2010 at 1:40:26 PM | Revit MEP 2010 plan region HVAC problems
mcewre
I am currently trying to use plan regions due to a complex residential type building that has multiple roof elevations. The problem I am having is when I set the view range on the region, the only thing that shows up is mehcanical equipment and fittings. My ductwork and piping does not show. I know there has been issues with duct line gaps and that setting making ducts not show up properly. I have already set my gaps to 0 and it still does not work. Attached is a screen capture of one area I am having problems with. Any suggestions would be greatly apprecciated.
Thanks,Eric
Wed, Sep 28, 2011 at 6:20:17 AM | Revit MEP 2010 plan region HVAC problems
RobDraw
Did you ever get a solution to this problem?
I have the opposite problem where the ducts are showing and the equipment and fittings are not.
Rob
can revit create hvac fabrication drawings???? help!!!! revit MEP 2009
Fri, May 7, 2010 at 12:00:48 AM
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:58 AM
Revit MEP HVAC Lag?
Wed, Jul 4, 2012 at 10:58:46 AM
thermostat in hvac system R-MEP-2009
Wed, Jan 21, 2009 at 5:02:53 PM
REVIT MEP 2010
Fri, Dec 11, 2009 at 3:09:26 PM
Page generation time: 2.0078
