60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Drawing List Help - merging columns or making lines 'invisable'
Mon, Mar 29, 2010 at 4:59:09 PM | Drawing List Help - merging columns or making lines 'invisable'
CHEIF
Hello everyone.
Im having trouble developing my drawing list. Im currently trying to match our office standard index, which is autocad based. Im trying to combinded my 'drawing no' and the 'sheet number' columns to achieve one column.
Ive attached two images to help. The white background is the revit one and the black background is what im trying to match. Also if anyone knows how to make the lines go all the way throgh the row spaces that would also help.
Thanks
Mon, Mar 29, 2010 at 5:11:52 PM | Drawing List Help - merging columns or making lines 'invisable'
3.5 Stars: 395 Votes
You don't have that kind of control in revit.  Either adapt your standards or turn off the grid lines and add those manually.
Tue, Mar 30, 2010 at 9:54:44 PM | Drawing List Help - merging columns or making lines 'invisable'
CHEIF
Thanks for the reply.
How can i turn off the grid lines? can i do this so the text still stays on?
Thanks again
Wed, Mar 31, 2010 at 6:43:25 AM | Drawing List Help - merging columns or making lines 'invisable'
In your schedule setup - appearance.
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Column sizes in the Drawing List
Mon, Jul 13, 2009 at 2:24:16 PM
When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e
Fri, Jun 11, 2021 at 7:44:53 AM
DRAWING LIST RUNNING HORIZONTALLY '09
Fri, Sep 19, 2008 at 3:18:09 PM
Page generation time: 1.4868
