51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Slab vs. Floor
Sun, Feb 28, 2010 at 3:37:47 AM | Slab vs. Floor
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
when i create a structural foundation slab on level one i
can't see it because the view range doesn't go below
level one for that.. BUT when i create a floor that sits
in the exact same position- i CAN see it- and it has all
the exact same view range settings..
why is that?
Sun, Feb 28, 2010 at 3:46:13 AM | Slab vs. Floor
Kardiff
5 Stars: 3 Votes
Floor slab probably counts as topography is the graphics override
and as default topo is off on floor plans (if i remember correct)
so turn topo on and see if it appears
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Sun, Feb 28, 2010 at 4:12:14 PM | Slab vs. Floor
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks Kardiff-
all catagories and sub catagories are turned on in VG..
the foundation slab sits in the exact same position as
the floor slab- but the visability is different.. i'm spending
a lot of time searching for the reason why..
Sun, Feb 28, 2010 at 4:32:33 PM | Slab vs. Floor
Kardiff
5 Stars: 3 Votes
Interesting, ill have a play when I get into work tomorrow
could have something to do with the cut/fill pattern but I won't know without having a good play in the office
but it's definatly work a look into
Sun, Feb 28, 2010 at 4:45:20 PM | Slab vs. Floor
Kardiff
5 Stars: 3 Votes
Sorry, had to try it out
Images shown belowI have a foundation slab shown at level 1
visible in plan
you must of overlooked a graphic override or your view depths, or it could be a bug
(done on RAC2010 student)
Sun, Feb 28, 2010 at 5:29:28 PM | Slab vs. Floor
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
poof- it's gone..
Mon, Mar 1, 2010 at 1:57:00 AM | Slab vs. Floor
Kardiff
5 Stars: 3 Votes
Send you attach an image or your view range / graphics overriide
or load up from prooject with the magic slab ?
Mon, Mar 1, 2010 at 7:39:10 AM | Slab vs. Floor
3.5 Stars: 391 Votes
Folks - I keep telling you to read your HELP !!!  Under the topic "
Adding Foundation Slabs
8.  Click the foundation, and select the desired Foundation family type on the Family drop-down list.
NoteFoundation slabs are added below the level in which they are drawn. Therefore, if you add a foundation slab in Level 1, it is added below Level 1 and will not be visible in the Level 1 plan view. To see the foundation slab in a plan view, create a new level below Level 1, for example, Foundation Level. When you create a new level below Level 1, you will also be able to see the foundation slab as an underlay (displayed in halftone) in Level 1.
Tue, Mar 2, 2010 at 7:24:31 PM | Slab vs. Floor
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
so is a floor- but you can see it.. notice my origianl question..
and this is not addressed in help..
why the floor is put in the exact same way in the
exact same position- but one you can see and one
you can't.. that's the question..
Wed, Mar 3, 2010 at 7:05:38 AM | Slab vs. Floor
WY1S1WYG,
Did you read this.....The HELP specifically says that a foundation slab WILL NOT show! It is in a different category than a floor slab!!!!  And yes ... it is different.....
Thu, Mar 4, 2010 at 12:32:43 AM | Slab vs. Floor
#11
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks Hub-
this is amazing- i keep repeating the same question-
but i keep getting the same answer to a different question..
question again:
a foundation slab will NOT show- just like it says in help..
a floor WILL show..
and although both are in a different category- they both
look exactly the same and operate the same..
WHY DOES ONE SHOW AND ONE NOT SHOW??
why=reason.. what is the REASON one shows
and one don't??
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Floor Slab Slope
Tue, Jan 30, 2007 at 11:01:08 AM
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:01 AM
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
varying slab thicknesses
Thu, Sep 27, 2007 at 2:12:31 PM
Page generation time: 2.4891
