52 Users Online (51 Members):
Forums >> Community >> Newbies >> Deleted Topo Surface
6 Posts No Rating |
Brand new to revit here - I split my topo surface attempting to add a sidewalk and deleted the whole thing. I did not realize this until later - after multiple saves and closing of the file. Now I think there is a big "hole" in my surface where there is nothing, (right?). Is there a way to restore the previous surface?
6 Posts No Rating |
BTW - using Revit 2010
iF YOU HAVE AN OLDER COPY, YOU CAN OPEN THAT UP DETACHED FROM CENTRAL AND COPY/PASTE YOUR SITE BACK IN. Sorry for the CAPS
This happened to me too, I wonder if it is a glitch in 2010. The only solution I could find was to re-insert the points of the topo surface.
10 Posts No Rating |
BTW - using Revit 2010 ___________________________________ Uggs UGG boots
Edited on: Tue, Apr 6, 2010 at 12:24:57 AM
I figured out that if you place an object connecting the two surfaces, then it fixes the problem for some reason.
How to infill a topo hole from plit surface |
Fri, Jun 15, 2012 at 9:54:54 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
placing a street, vegetation and barrier or railing on topo surface |
Tue, Jan 17, 2017 at 5:47:40 AM
lines on topo surface |
Wed, Aug 3, 2011 at 8:37:21 AM
Members: | 2000436 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
