66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Create Work views
17 Posts No Rating |
hi, does anyone know, how to make a work view???...i don`t know if this is the correct name fot this kind of views, but i know you can kind of lock the views for sheets, and have other views unlocked to work; so the views on sheets will never change, doesnt matter how many people works on the project... hope u could understand me...
12 Posts No Rating |
Cant you just create the view that you want get it set up how you want. Then right click the view and create a duplicate of the view. Label it "Work view of example"? I dont fully understand what it is that you are trying to do but I hope duplicating the view works.
Thanks FwasDrafter... i already work the way you said...but i`ve heard about a special view, i dont know if is locked or what...but this views are in the sheets...and is allowed to work in them just if you`re in the sheet, u cant enter direct to the view through the browser organisation...
You could filter your browser so that only views show that are not placed on sheets.
I know that once you place a view on a sheet you can activate the view and work on the view directly from the sheet. Is that what you are refering to....the Activate View command? cause you can do that either in the menu bar or by right clicking the view itself.
i know how activate view command works....thanks, and is not what im trying to do... but may be with the filter in the browser works...i tried to do that, but i dont know how filter views that arent on sheets... how do you do that WWHub???
Thanks so much!!!!, i already do it...i just filter the browser by sheet name, equal to none...so... my browser just show me those views that arent on sheets... thanks so much!!!!!!
how does view ranges work in ceiling views? |
Sat, May 11, 2019 at 2:42:35 PM
13
How to create isometriv views in revit architecture 2009 ? |
Wed, Nov 19, 2008 at 12:40:08 PM
creating different views for a new family |
Sun, Jan 8, 2006 at 12:03:06 PM
Duplicate views create duplicate callout tags in referring views... |
Fri, Mar 9, 2012 at 1:37:25 PM
Creating Views |
Mon, Feb 21, 2011 at 8:57:49 AM
Members: | 2000355 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
