58 Users Online (57 Members):
Forums >> Community >> Newbies >> Property lines cause drawing to disappear
4 Posts No Rating |
I am working with revit 2010. I recently attempted to add a property line to a model to create a site plan. When I did this, almost everything in the model vanished. Some text stayed behind and a few traces of some model elements but otherwise it was all gone. When I delete the PL, it all comes back. It's as if the PL is covering the model. I am still quite new with some of revits functions this being one. I have gone through every properties dialogue window I can find, I have tried changing levels, and on and on but nothing seems to work. I have put the property lines in other models with no trouble at all. I am totaly lost and a little desperate. Anyone have some solutions?!!!
I think i can't understand this one... can you put some images to figured out??
4 Posts No Rating |
here are 2 pdf file 1 without the property line and one with.
Did somebody solve this problem (this isn't a newbie problem) We get the some problem here.....
i don't have any problem.
Without having the model, I can only speculate as to what you may be doing, but I bet you have added a topo surface that is above most of your model elements. Might want to spin your 3D model and take a look - even upside down.
Solved the problem, delete the plan (site) en create a new plan site...and it shows the boundery line and model correct
I had this happen to a view once, though I attributed the problems to turning on 3d acceleration in the graphics options.
Property Lines + True North Rotation |
Thu, Apr 26, 2012 at 2:34:45 PM
Section lines disappear |
Thu, Nov 26, 2009 at 5:14:07 PM
Property Lines on Toposurface |
Mon, Jul 9, 2007 at 10:22:49 AM
property lines hidden by topography |
Tue, Mar 6, 2007 at 11:47:47 AM
Progataing property lines to floors |
Fri, Mar 18, 2011 at 4:25:43 PM
Members: | 2005663 | Objects: | 22910 | Forum Posts: | 152188 | Job Listings: | 3 |
