82 Users Online (81 Members):
Forums >> Revit Structure >> Technical Support >> Wall end at an angle
6 Posts No Rating |
How can I adjust the wall ends. For a project there is a gidsystem at different angles. the solid concrete walls have to be alligned to those grids at both ends. is there a quick way to adjust the ends of a wall (see attachted file the ends of the wall have to be parralel to the grid "as n57" ) Of coure there is the option to make the walls bigger and remove some with a vertical wall sweep or a in-place void but is there no easy way to modify the walls; when I ad another wall allong that grid at an angle REVIT will make a nice join; Unfortunately i need a gap before the next wall starts. Is there an easy way to tell my wall that the end need to be alligned to a ref plane or something like that?
Edited on: Tue, Jan 26, 2010 at 5:04:06 AM
Where is the "Attached file"???
6 Posts No Rating |
Here is the attached file; the file was to large so I made a scetch to explain.
7 Posts No Rating |
I've always wondered this, too (wall joins have always been one of revit's biggest problems). I just made the thinnest wall possible and mitered it to the end of the wall in question. Construction-wise, it would have to be done the same way (with some sort of bead or wall cap) and with the line thicknesses, you can't even see the tiny wall. I would like to know if there is a better way, though.
we came up with an innovative solution. Create a new wall that is in the position of the cut you want. Put it in a future phase (that will never be shown). Voila. The new wall cuts a hole in the existing one.
I've always used a simple family for this. I think that is more Revit's way rather than a "future" wall that would show up if someone wasn't careful.
how to angle end of wall |
Wed, Jul 23, 2008 at 1:37:15 PM
Vertical reveals to angle wall end |
Mon, May 11, 2009 at 11:36:00 AM
Angle curtain wall |
Thu, Jan 24, 2013 at 3:00:57 PM
create a wall sweep on an angled wall (gable end wall) (2017) |
Wed, Aug 3, 2016 at 2:29:53 PM
Curtain wall to wall at an angle |
Tue, Jun 12, 2018 at 2:38:49 PM
Members: | 1999760 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
