132 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> CAD Remnants
Tue, Dec 22, 2009 at 4:10:50 PM | CAD Remnants
bert
Hello!
Over the last year, I've been adding to our companies Revit template and everything came along really well, but I did notice that some CAD files I had once linked in have left behind some DNA. Looking at Object Styles > Imported Objects, I noticed files I've long removed from my template file. How can I completely remove these?
I am able to remove the individual layers, but not the file name (see attached image).
Any suggestions, as always, would be greatly appreciated. T
Thanks!!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Tue, Dec 22, 2009 at 4:36:45 PM | CAD Remnants
3.5 Stars: 391 Votes
Check out any standard details you have loaded.  Could be hidden in view.
Tue, Jan 5, 2010 at 7:47:36 AM | CAD Remnants
bert
I couldn't find any hidden CAD files. I checked 'Manage Links' and none are there, but still those Imported Object Styles remain.
using RAC-2013
Tue, Jan 5, 2010 at 11:21:26 AM | CAD Remnants
Look at the name of this CAD file "Roof Details.dwg".  You (someone) probably used this in a detail and then hid the CAD drawing.... Your assignment, should you accept it.... this reply will self distruct... sorry - probably before your time.
Good luck in finding this but it will be a learning experience and I'm sure a point of discussion with others on your team.
Tue, Jan 5, 2010 at 12:38:35 PM | CAD Remnants
bert
Actually no, these are/were files I used and removed; I am the only person working on this template file. I had already checked for hidden files, and even removed all views, sheets etc etc to see what's left over. the files listed as shown in the image were left unchanged.
I'll gladly accept a new mission.
using RAC-2013
Tue, Jan 5, 2010 at 12:50:09 PM | CAD Remnants
These are the hardest items to find.  What's left maybe families ???
Also ... I don't know how these could remain ...but maybe - Do you have any over-ride sttings in view templates - VG- overrides-imported categories....?
Tue, Jan 5, 2010 at 1:08:46 PM | CAD Remnants
bert
Looking at the names, these files were all imported/linked into the main file, and not in families. I'm clueless. Also nothing in View Templates.
I tried out both importing and linking a CAD file with a few layers, checked the object styles (they showed up), removed the file and checked the object styles again (they were gone again). I don't understand why those others would still remain when I'm doing the exact same thing here.
using RAC-2013
Tue, Jan 5, 2010 at 5:01:27 PM | CAD Remnants
Check out one of the utilities on this link - it may help. http://www.revittools.info/
Thu, Jan 21, 2010 at 10:18:13 AM | CAD Remnants
bert
Still no success WWHub. Sad
using RAC-2013
Thu, Jan 21, 2010 at 8:03:51 PM | CAD Remnants
You obviously opened all views ... did a reveal hidden elements... turned on everything and all imports....
Here is a suggestion.  Start purging everything in your file from the browser including elements in use.  Do it a cluster at a time.  Start with model then detail families.  When it finally drops, you will have it isolated.
You can then open a new copy and remove only the problem.
Thu, Jan 21, 2010 at 8:28:23 PM | CAD Remnants
#11
bert
Actually, that's something I had done a long time ago, yet I always assumed it would be part of a view or something alike, so I never went to Purge the remaining partin of the template.
It doesn't really make sense, but I found it as a Family with one of the CAD names, which then contained every other CAD file that was also listed there.
Whatever it was, I'm glad it's gone!! Thanks WWHub!!
using RAC-2013
Thu, Jan 5, 2012 at 10:57:21 AM | CAD Remnants
#12
skyman111
WWhub - thanks for the link to Revit Tools - I had this same problem but installing that Revit Tools plugin and using the manage imported objects utility allowed me to rid my project of old CAD .  Fixed a major visibility problem (walls appeared transparent in many views....).   Thanks!
Wed, Aug 15, 2012 at 10:25:28 PM | CAD Remnants
#13
Ammar
if these CAD files are directly imported then this is the cure:
http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3apurgecads%3aen
it'll find them, let you know where are they, and delete them if you want
Wed, May 17, 2017 at 11:20:58 PM | CAD Remnants
#14
k065167
Sorry, I know this thread is old, but I still have this issue even with Revit 2018!
Wanted to try WWHub's tool since it sounded like that would solve my other big problem: transparent walls in views! However, the link took me to a technology blog with no visible button to download this tool. May I have a new link please?
Meanwhile, I'll keep using DWG Explorer to directly remove imported categories from VG as well as to delete imported dwgs from the model without having to find them first. Can I do the same with revittools?
Purging CAD files
Fri, May 19, 2017 at 12:06:54 AM
export layers, purge
Wed, Jun 3, 2009 at 10:20:58 AM
Solution 2D DWG to REVIT Pls
Sat, Jun 17, 2006 at 12:43:29 PM
Linked Cad File does not show Cad Xref's
Fri, Sep 10, 2010 at 10:13:50 AM
Revit to CAD then use current cad layer standard, how?
Sat, Mar 10, 2012 at 8:42:45 AM
Page generation time: 0.4404
