54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Best Practice for standard notes within drawings
I do mostly residential projects, and as such the notes for wall types etc are usually on the drawing and not in a legend. Also the notes are typically very similar from project to project. What is the best way of importing these into each project? (Please see attachment for example) Should I be setting up tags, Keynotes, copying text? Thanks.
www.globaldesignstudio.com
Be Inspired! |
I would definitely be using a tag or a keynote. The simplest solution would probably be to set up a tag that reads the Comments parameter, and entering the note in the wall type in your template.
Thanks for the reply. How do I do multiline text in the comments parameter. I had tried this earlier, but both the Comments and Description both only have single line values do they not?
Be Inspired! |
Check this video out: http://revittotd.com/07/527
The method WWHub posted works to force where the breaks are, otherwise the text will automatically wrap to the width of the label in the tag family. When you select the label you will get two grips just like a text object. However long you stretch those will be the max width of your text. Edit: Another thing you might want to consider is creating a new shared parameter called something like "Standard Notes", then you can fill that out instead of using the Comments or Description. It's not necessary, but in my mind it keeps things a little more organized.
Edited on: Thu, Dec 10, 2009 at 10:42:04 AM
best practice for construction notes in Revit |
Mon, Mar 16, 2015 at 2:32:24 PM
Creating notes on drawings |
Wed, Jan 21, 2009 at 10:22:02 AM
Production Text Notes - Global Visibility |
Wed, Mar 8, 2017 at 1:43:55 PM
standard note blocks |
Fri, Mar 7, 2008 at 10:22:22 AM
Keyed Notes in Drafting View |
Mon, Mar 15, 2010 at 4:25:44 PM
Members: | 2000461 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
