Forums >> Revit Building >> Technical Support >> Topo point does not import?
24 Posts No Rating |
I have a building in revit 2010 and I am trying to import the survey to create the site. I put the footprint of the building in the survey at the right height so i can properly locate my building the survey i got only have point/nodes, but not contour lines. (i checked and they are at the right height) When I link the Cad file, non of the points imoprted, only the building footprint. (when i select it I can see the selectiong box right around my footprint) and I can make a topo from my footprint no problem, which doesn't really help me. anyone has any clue how to fix this problem? thanx in advance
Do you have CAD??? if so use this LISP routine to create a CSV file by the points you have in the CAD file, then in Revit you can import those points...
awesome!!! exactly what i need. Though I dont' know much about Lisp but it's not hard to figure out how to use them For future viewer who know as little as me: 1) Go to menu Tools> Customization>Import> right click where you see lisp to load lisp (make sure you are in the customization tab) 2) type "RCPV" in your command line, then just follow the instruction and you are done!! Thanks typhoon
Your Welcome, i'm glad you can solve the problem...I translate that to English (it was in Portuguese) to be more easy for you understand how it work....
Edited on: Wed, Dec 9, 2009 at 2:00:42 PM
"Modeling Topos" & Topo's from grade or point?!?! Topo Conceptual Mass? |
Fri, Aug 4, 2017 at 5:52:32 AM
level elevation doesn't match elev point in topo / site plan |
Wed, Dec 18, 2013 at 4:05:01 AM
13
Topo Surface From CAD Import |
Mon, Mar 2, 2020 at 7:52:44 AM
Topography Elevation from Project Base and Survey Point is Incorrect |
Thu, Jan 29, 2015 at 10:32:25 PM
Invisible Topo |
Mon, Jan 27, 2014 at 10:25:30 AM
Members: | 2096599 | Objects: | 23163 | Forum Posts: | 152287 | Job Listings: | 3 |
