66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> CAD to REVIT
Tue, Dec 8, 2009 at 1:36:47 PM | CAD to REVIT
BiggieP
File started in Revit - brought into CAD for development and now wish to convert DWG back in to Revit.
When I load file into Revit I cannot perform partial explode.
 File is one large DWG.  I have attemped to explode file in CAD prior to bringing it in.
 thanks
P
Tue, Dec 8, 2009 at 3:02:54 PM | CAD to REVIT
TKennedy
4 Stars: 7 Votes
My first question would be why are you tryint to explode the dwg in Revit? It's pretty much always a bad idea, and creates more issues than it solves.
Tue, Dec 8, 2009 at 3:09:20 PM | CAD to REVIT
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ditto.  Explode DWG = BAD
Is it a 3D DWG file?  Best to leave it unexploded and trace it or use pick tool.
Regards,
Chris.
Tue, Dec 8, 2009 at 3:19:35 PM | CAD to REVIT
BiggieP
I was under the impression that a cad file once brought in should be partially exploded so that the lines can be given a line weight in Revit.  As long as there is no block this allows for a crossing select and easier shifting of the laters.
 yes, the plan is 3d
 thanks - anything additional is appreciated.
P
Tue, Dec 8, 2009 at 3:37:28 PM | CAD to REVIT
cheryla
3 Stars: 2 Votes
If you are working in Revit, stay in Revit, is my opinion. Going back and forth is really not a good idea. You can draw lines in Revit if you don't want to model everything.
Cheryl Nelson
Randall W. Hein Architects
Tue, Dec 8, 2009 at 3:44:43 PM | CAD to REVIT
TKennedy
4 Stars: 7 Votes
You don't need to explode the dwg to assign lineweights/styles. Go to the "Imported Objects" tab in Object Styles and you can adjust each layer in the dwg.
Revit to CAD then use current cad layer standard, how?
Sat, Mar 10, 2012 at 8:42:46 AM
Linked CAD ducts/pipes not showing up in Revit Structure 2013
Fri, Jul 10, 2015 at 8:36:43 AM
13
Auto Cad 3D and Revit 2009
Thu, Aug 20, 2009 at 7:18:40 PM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:11 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:57 AM
Page generation time: 2.1158
