98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> RENDER NOT HAPPENING...
Have done a scheme for a house.
Last worked on it a week ago when it would render ok.
Have opened up drawing today and now the render will not work despite not having changed any settings.
When I try to render, it just goes back to the command prompt (as it where!) and waits for next command.
Has anyone come across this ?
I have imported a couple of cars (from this site) but have now removed these, purged and refreshed. These are the only potential cause of the problem I could think of but render still does not work.
Other projects are still rendering ok so I know it is file specific ????
I have experienced this also. Have never been able to diagnose the cause and its typically been on large files. Usually decides to work again after a few days of working on it... Have you tried it on another PC?
I think the quickest fix you are going to get will be sending to support...
I found the problem at last. Trial and error as usual. In revit 8 it was the fruit tree family. Whenever I got rid of these the render worked. When I put them into a project the render did not work. It has taught me to regularly test rendering is ok after loading families into projects.
Elements Missing in Render Image |
Mon, Sep 27, 2010 at 7:21:17 AM
Revit render solarized? |
Wed, Apr 17, 2013 at 9:50:43 AM
Render Calculation Error? [ 1 2 ] |
Fri, Jun 7, 2013 at 7:53:38 AM
19
Render goes ok but when i change angle - the render is black |
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render or 3ds max design render? |
Sun, Jan 4, 2015 at 10:19:29 AM
Members: | 1999329 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
