16 Users Online (15 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> How to make a conceptual mass triangle?
Wed, Oct 14, 2009 at 8:33:07 AM | How to make a conceptual mass triangle?
Huibert
Hello everyone,
I am rather new to revit structures. Our company is in the prefab concrete and we are currently looking if revit structures is a good candidate for our drawings; but I already encounter some problems.
I have a project with consists of a construction 4 inclined triangular schaped 'facet' walls (as finishing of an bycicle passage under a highway). These 4 walls will be at every corner of the passage, so 16 elements per passage. And i have to do it for 14 passages, each having different initial conditions (different angles different dimentions, but the same kind of layout).
 My idea was to make a conceptual mass and then place wall on the surfaces of the created mass. But here i have a problem. How to create a conceptual mass wich is a piramid with a triangular base (no corners of 90 deg.). When i create a mass it always needs a line or a plane and it refuses to use a single point as 'frame' for my mass.
Other ways of creating a mass with the desired faces failed because Revit never connects the frames as i want. For example when i have a square and a triangle as frame it never connect one point of the square to 2 points of the trainge. And when i try to redirect the edges it gives errors like "can't make zero lengt lines"
can someone give me some advise how to continue?
 Huibert
Wed, Oct 14, 2009 at 12:42:35 PM | How to make a conceptual mass triangle?
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
3d snapping goes a long way.  this is just a simple tetrahedron.  if you really want an effective answer however, you should probably post an image of what you're trying to create.
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:37 AM
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:06 PM
Scaling Conceptual Mass
Mon, Oct 11, 2010 at 7:34:52 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:56 PM
Conceptual Mass: Revit Architecture 2012 (Trial V.)
Mon, Jun 30, 2014 at 7:20:06 AM
Page generation time: 0.8785
