66 Users Online (65 Members):
Forums >> Community >> Newbies >> Topo Surface from autocad into revit
2 Posts No Rating |
Please help. I have prepared a topo surface in autocad (which is attached) When I create a toposurface from it in Revit. It looks awful. It has wacky triangular "spikes" everywhere. I created the topo surface in autocad using polylines with specified z values. When I view it in autocad using orbit it looks fine. Is there a way to get Revit to create a smoother topo surface from this clean data. This has happened before but not this bad Thank You.
Don't use REVIT to produce topo drawings. It just doesn't work well for that. For your REVIT model, you would be better off to have your original site and use PADS to create your levels. I am asuming that you will have walls around those flat areas.
6 Posts No Rating |
Hello, I've done some topo surface with revit and it worked fin "for me". If you want to extract topo points from autocad and import it in revit go see that forum http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6289 Survey points works fine if imported in revit. Good luck
something like this, use the topography complete and pads to the levels
oops, too big file size, ill upload on rapidshare http://rapidshare.com/files/292730328/likethis.rvt.html
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
lines on topo surface |
Wed, Aug 3, 2011 at 8:37:21 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Creating Revit Topo from AutoCAD file |
Wed, Mar 7, 2018 at 8:30:50 AM
Deleted Topo Surface |
Fri, Apr 2, 2010 at 3:54:58 PM
Members: | 2000453 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
