49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Grouping Floors
Mon, Aug 22, 2005 at 2:50:37 PM | Grouping Floors
n8dogg
I am having difficulty grouping multiple/typical floors in R7.0. Id like to be able to edit one floor of the group and have the entire group of floors updated accordingly (i.e for openings/penetrations etc.). Unfortunatley, it appears the array command does not function properly w/ floors. Grouping of individual floors is not working either (cannot edit single instance in group). Ive tried using floors created w/ Building Maker (massing) and floors created indepentently, neither seem to work. Any ideas would be appreciated
Mon, Aug 22, 2005 at 3:47:49 PM | RE: Grouping Floors
TomDorner
4.5 Stars: 25 Votes
I get this to work just fine in 8.1. Don't know about 7.0 as that is long gone from my system but it should work. Make sure you group the floor first, then array. Of course you should really use 8.1 to take advantage of the new shaft opening tool. HTH Tom
Grouping Walls and attaching them to Floors
Mon, Feb 15, 2010 at 4:10:51 PM
How to lock walls so they move together
Tue, Dec 21, 2010 at 12:07:18 PM
Graphical Column Schedule - Not Grouping all similar instances
Wed, Nov 5, 2008 at 11:11:18 AM
Grouping issue
Mon, Dec 19, 2016 at 12:12:45 PM
Grouping Line-based Families
Mon, Oct 30, 2006 at 12:00:45 PM
Page generation time: 0.2580
