86 Users Online (85 Members):
Forums >> Revit Building >> Technical Support >> Rendering on 2 cores.... wait... make that one
8 Posts No Rating |
About an hour after I hit the render button, i come back to the computer to see that the process has moved quite slow. When i pull up the task manager i find out that mental ray was only using 1 core to render, when not 30min prior it was using both cores. Anyone have this happen? Went at it again this morning and it was indeed using both cores, but after about 25min, it went back to one and i stopped it after 10min of single core usage.
8 Posts No Rating |
RAC 2010 sorry
That has got to be an OS issue it sounds like. I don't use Revit for rendering much but as you can see it is using all 8 cores eventho it is not using them at 100%
8 Posts No Rating |
Well i thought that i had limited it to a single view. But i had another view make it 99% through the rendering and then one of the processors dropped off. Really weird stuff. I may have to take a look at my processor and see if everything is alright.
New system, need CPU help |
Thu, May 13, 2010 at 10:32:06 PM
Rendering and Number of Cores |
Tue, Feb 7, 2012 at 12:19:57 PM
Will Revit and autoCAD 2012 and newer use more than 4 cores for 3d draftnig? |
Tue, Jun 26, 2012 at 11:13:35 PM
Material Browser Wait Time |
Thu, Apr 18, 2013 at 10:40:04 AM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 3 ] |
Sat, Apr 4, 2009 at 1:38:57 AM
30
Members: | 2001116 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
