62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
When a sheet has multiple scaled views, the sheet scale label shows "As indicated" This sucks. I want it to read "AS SHOWN" Come on guys - first off, most text is ALL CAPS!! WHERE can I change this? I plan to take some API classes at Autodesk University. Would this be helpful to get under th covers and fix what cant be changed thoruhg the UI? Any other ideas? Thanks.
----------------------------------- Revit Architecture 2010 |
Remember .... RevitCITY is not AutoDESK. You are welcome to vent here but it will not change this. Contact AutoDESK.
I realize that! I was venting AND looking for a work around solution one of you may have come across. It was also written with humor in mind - guess it didn't go over well. Thanks.
I would also appreciate if revit could show "1:500, 1:200" like archicad does...
Nessie
Revit 2013 |
Can titleblock scale only reference one of many views on the sheet? |
Sun, Apr 14, 2013 at 10:46:46 PM
Default Scale List editing - how is it done? |
Mon, Nov 5, 2012 at 8:53:55 AM
Printing views to scale? |
Fri, Aug 31, 2007 at 8:33:25 AM
How do you scale a sheet? |
Tue, Nov 7, 2006 at 5:58:13 PM
Scale Value Default Modification |
Thu, Apr 2, 2015 at 1:55:43 PM
Members: | 1998761 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
