65 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Downloaded BIM objects from Revitcity freezes my Revit program
Sometimes when i download a bim object from REvitcity and after I save it into my Imperial Library when I try to load the component it creates an terminal werror and revits closes. Can someone help me with it. I happens more often than not. Thanks
You don't give enough information to really answer. What is the size of the family? What is your system? Sounds like memory issues to me.
I am using a pentium 4 with 2.25 GB of ram and windows xp proffessional. I can add components from revit library ok but when I dadd components that have been downloaded into the library from revit city most of the times my revit arch 2009 stops running closes and save the file into a recovery file. There are times when I do not have a problem but it is rare.
I try to open the family to view it by itself no file open and I get "An urecovable error has occurred. The program will now be terminated. All your data has been recently saved, so there is no need to cretae a recovery file." The file is 108 kb.
Uou do have memory issues ... recommended minimum is 4 GB... Clean your system. Run cc-cleaner or someting similar.
I have downloaded bim objects as a single file download and it works fine with revit. The problem starts when I group several objects to download and they download in a zip file. When I unzip the file then apparantly it corrupts itself. creating the error in my program.
Rendering with objects downloaded from revitcity |
Tue, Feb 27, 2007 at 2:34:24 PM
Revit Architecture 2010- Splash screen freezes |
Sun, Sep 20, 2009 at 2:45:37 PM
Revit freezes when opening sheet views |
Fri, May 11, 2012 at 5:23:01 PM
Changing colour for revit family downloaded from revitcity |
Fri, Nov 6, 2015 at 9:44:53 AM
bim objects |
Sun, Dec 7, 2014 at 10:01:38 AM
Members: | 2000483 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
