122 Users Online (121 Members):
Forums >> Revit Building >> Technical Support >> How to join 2 gable roof?
14 Posts No Rating |
Here is a Revit roof question; I am trying to attach two new gable roof to an existing roof I used cut geometry and join roof none of them seem to work. I used roof by footprint but that does not seem to give me the roof configuration that I am looking for. There fore I created 2 gable roofs and trying to joing them witrh existing in between and get the results that you see in the attached files. The attached file shows the gable roof to the right that I am trying to attach the gable roof with higher ridge in the middle. As you can see from the section I am not sucessfull in achieving joining the two. The third gable roof to the left I did not try to join it, hopefully I will with somebodies help Thanks Sudanhafif
About the roof to the right, it is very simple: draw a reference plane and where they intercept just use the split tool, see image shown. About the second roof, I'm not fully clear with it,,,,
Can't get Gable roof to Join Hip roof |
Wed, Aug 20, 2014 at 3:56:33 PM
Roof |
Fri, Dec 30, 2005 at 8:11:33 AM
Residential Roof - Can't join plan pitch with gable |
Wed, Aug 9, 2017 at 10:00:27 AM
Extending one gable roof into another |
Wed, Jun 11, 2008 at 3:09:42 PM
Joining a conical roof to a gable roof or other rectangular roof |
Tue, May 28, 2013 at 9:29:25 AM
Members: | 1994080 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
